Grafana Day Aggregates Doesn't Send Timezone? Why?
    grafana:10.3.3 via container on kubernetes
    influxdbv2.7
    Create 1 day windows of usage data
    Using influxQL and time series graph.
  • What happened?
    Data returned by data for today is in a window bucket for yesterday’s date because grafana does not send the timezone in the influxdb query.
    Grafana to send the timezone to correctly aggregate the data from data stored in UTC. I realize (after hours of confusion) that you need to as the Timezone in the “Timezone” field in the influxQL query builder but I can’t figure out why grafana doesn’t do this for me. Additionally there doesn’t seem to be a global variable for timezone in grafana so I can’t put a variable here to have this work as expected without additional scripting.
I tried adding the Timezone into the “Timezone” field for a graph I’m aggregating in Hour windows expecting this to break something, somehow, but it didn’t, which makes sense. However, I guess this would be necessary if you lived in a timezone with one of these 30 minute timezone offsets. So that user would probably be even more confused and frustrated. I at least saw that most of my graphs were correct so something unexpected was happening only in this condition.
I don’t understand why grafana doesn’t send the timezone in the query knowing that influxdb supports this? What use case don’t I understand that this isn’t the default behavior? And why isn’t there a timezone variable knowing that anyone doing Day aggregations would benefit from this? I must be misunderstanding or missing something.
    Query Inspector to get the query being run via POST:
    SELECT mean(“usage”) FROM “energy_usage” WHERE (“detailed” = ‘Day’ AND “channel_type”::tag != ‘Mains’ AND “channel_type”::tag != ‘VirtualMemberCircuit’) AND time >= 1706275287450ms and time <= 1708867287450ms GROUP BY time(1d), “device_name” fill(null) ORDER BY time ASC
Of course (now that I understand what’s wrong) running the same query in influxdb and simply adding the TZ at the end of it returns the data aggregated in my TZ and not UTC.
    No
    No
