Change themes and icons Grafana
good day
I would like to know the method to modify grafana themes from a standard installation in Debian, currently the server where it is installed has no nodejs / yarn, so I would like to know if there is a way to make changes to the themes without having to make a rebuild.
Beforehand thank you very much.
if you built from sources and you want to rebuild you can just run
./node_modules/webpack/bin/webpack.js --progress --colors --mode development --config scripts/webpack/webpack.dev.js
