Change template variable value from clickable links in table panel
I have a table panel and some graphs. In the table panel I have a list of environments and each row represents one environment and the columns have the env name and some summary values from that environment. The graphs are more detailed version of each value in the table.
I see that in table panel can have clickable links. I tried adding the a URL like ?var-env=${__cell} so then the value in the template variable droppdown will change. But its not changing and its just adding the url on in the address bar. I have to manually refresh it for it to load.
Is there a way to change the template variable dropdown by clicking a cell in the table panel?
Hi @amjad Did you find a solution for this?
Very interesting case. Anyone knows if this is possible?
did you find any solution to that ?
