Change size of circle when hovering over graph
Hello everyone,
I’m currently doing some changes to the design of Grafana, mostly concerning the css.
However, I can’t find out how to change the size of the circles which are shown when hovering over a graph:
grafik
Has anyone done that before?
Thanks in advance for any help!
Make your panel editable and navigate to visualization.
Change the point radius.
Example:
@malamgir thank you for your response, but that’s not what I mean.
I mean the circles which are shown only when hovering over a graph, marking the values displayed by the tooltip. They are used even if the draw mode isn’t Points. The cursor cross is missing in the screenshot:
grafik
