Is it possible to change the separator used in the CSV file that is attached to reporting emails?
Currently, the CSV file uses a comma (,) as the separator, but I would like to use a semicolon (
instead. Is there an option in the backend to configure or adjust the separator format for these exported CSV files?
No, Grafana currently does not provide a built-in option to change the CSV separator used in reporting email attachments.
