for years i’m a big fan of carpetplots to visualise my data and i was very excited when i found the carpetplot plugin for Grafana.
The plugin works great, as long as the time range is shorter than 19 days. When using longer time ranges the plugin stops visualizing correct.
Example 19d time range:
Example 20d time range:
The only thing i changed between those 2 pictures is the time range. If i change the size of the panel, it sometimes works with longer time ranges but i was never able to show more than 3 months of data which is not much for a charpetplot…
If anyone has a clou why this is happening please let me know. Thanks
My setup:
Grafana version 9.02
Win 10 with Firefox/Chrome
