Is there any way to create a card view in dashboard?
What is a card view? Can you post some screenshots?
In production monitoring dashboard, each machine is like a card which has certain panels. User has to scroll vertically down to view all the data. I was trying to explore if there’s any way to design the same horizontally and the carousel will auto scroll horizontally at fixed time.
Beautiful dashboard. I assume this is not grafana but you want to produce something similar in grafana?
This is possible using stats but wont be exactly the same. What is your data source? Let’s start with that and we can demo some possibilities
Actually, that is a Grafana - a light (“corporate”) theme is used.
should have know with the icon top right.
Yes, you are right this is Grafana and queries are mix of ES, MySql datasources.
