Can't see older logs
I’m new to loki, my collection is done even if I don’t have the information I’m looking for yet. However, when I want to see the previous logs I get this error:
Query error
invalid query, through < from (2021-10-11 11:54:30 +0000 UTC < 2021-10-11 11:54:33.553910071 +0000 UTC m=+265418.724858378)
Here is my loki configuration file :
    auth_enabled: false
    server:
      http_listen_port: 3100
    distributor:
      ring:
        kvstore:
          store: memberlist
    memberlist:
      join_members:
        - loki-memberlist
    ingester:
      lifecycler:
        ring:
          kvstore:
            store: memberlist
          replication_factor: 1
      chunk_target_size: 1536000
      max_chunk_age: 4h
      chunk_idle_period: 4h
      chunk_block_size: 262144
      chunk_encoding: snappy
      chunk_retain_period: 2h
      max_transfer_retries: 0
    limits_config:
      enforce_metric_name: false
      reject_old_samples: false
      reject_old_samples_max_age: 730h
      max_cache_freshness_per_query: 10m
      retention_period: 48h
    schema_config:
      configs:
          store: boltdb-shipper
          object_store: filesystem
          schema: v11
          index:
            prefix: loki_index_
            period: 24h
    storage_config:
      boltdb_shipper:
        shared_store: filesystem
        active_index_directory: /var/loki/index
        cache_location: /var/loki/cache
        cache_ttl: 168h
        index_gateway_client:
          server_address: dns:///loki-index-gateway:9095
      filesystem:
        directory: /var/loki/chunks
    chunk_store_config:
      max_look_back_period: 10s
    table_manager:
      retention_deletes_enabled: false
      retention_period: 0s
    querier:
      query_timeout: 10m
    query_range:
      align_queries_with_step: true
      max_retries: 10
      split_queries_by_interval: 15m
      cache_results: true
      results_cache:
        cache:
          enable_fifocache: true
          fifocache:
            max_size_items: 1024
            validity: 24h
    frontend_worker:
      frontend_address: loki-query-frontend:9095
    frontend:
      log_queries_longer_than: 5s
      compress_responses: true
      tail_proxy_url: http://loki-querier:3100
    compactor:
      working_directory: /var/loki/compactor
      compaction_interval: 5m
      retention_enabled: true
      retention_delete_delay: 24h
      retention_delete_worker_count: 300
    ruler:
      storage:
        type: local
        local:
          directory: /etc/loki/rules
      ring:
        kvstore:
          store: memberlist
      rule_path: /tmp/loki/scratch
      alertmanager_url: http://prometheus-alertmanager.monitoring.svc.cluster.local
      enable_api: true
I am having the similar error.
Checking chunk_store_config: max_look_back_period may help.
