Can't remove/update provisioned datasource
Grafana v10.1.5 (849c612fcb)
I’ve provisioned a datasource without specifiying uid. So I can’t share provisioned dashboards between all instances.
So I just want the datasource to have same and fixed uid over all instances.
  1. I tried to just update the YAML file
  2. I tried to remove from Web UI
  3. I removed it from YAML file
  4. I added deleteDatasources in YAML file
  5. I tried to trigger a datasource reload from API with Admin service account token
  6. I tried to remove datasource from API by id with Admin service account token
  7. I tried to remove datasource from API by uid with Admin service account token
What happened?
  1. Nothing
  2. Can’t. Delete button is disabled
  3. Nothing
  4. Nothing
  5. I get 403 Forbidden while service acount is Admin
  "accessErrorId": "ACE4020887645",
  "message": "You'll need additional permissions to perform this action. Permissions needed: provisioning:reload",
  "title": "Access denied"
  1. I get 403 Forbidden while service acount is Admin (no detail)
  2. I get 403 Forbidden while service acount is Admin (no detail)
Be able to update uid or just remove datasource the provisioned a new one.
Initial one:
# datasources.yaml
apiVersion: 1
datasources:
- name: "Loki"
  type: "loki"
  access: "proxy"
  url: "http://loki:3100"
Update with uid:
# datasources.yaml
apiVersion: 1
datasources:
- name: "Loki"`
  uid: "loki"
  type: "loki"
  access: "proxy"
Remove:
# datasources.yaml
apiVersion: 1
datasources: []
Delete:
# datasources.yaml
apiVersion: 1
deleteDatasources:
- name: "Loki"
  orgId: 1
datasources: []
Did you receive any errors in the Grafana UI or in related logs? If so, please tell us
logger=context userId=15 orgId=1 uname=sa-temporary-debugger t=2025-04-10T06:32:34.146612002Z level=info msg="Access denied" userID=15 accessErrorID=ACE4020887645 permissions="action:provisioning:reload scopes:provisioners:datasources"
logger=context userId=15 orgId=1 uname=sa-temporary-debugger t=2025-04-10T06:32:34.148099058Z level=info msg="Request Completed" method=POST path=/api/admin/provisioning/datasources/reload status=403 remote_addr=[::1] time_ms=35 duration=35.434207ms size=169 referer= handler=/api/admin/provisioning/datasources/reload
logger=context userId=15 orgId=1 uname=sa-temporary-debugger t=2025-04-10T06:42:38.283540167Z level=info msg="Request Completed" method=DELETE path=/api/datasources/3 status=403 remote_addr=[::1] time_ms=22 duration=22.754428ms size=49 referer= handler=/api/datasources/:id
logger=context userId=15 orgId=1 uname=sa-temporary-debugger t=2025-04-10T06:43:39.126622718Z level=info msg="Request Completed" method=DELETE path=/api/datasources/uid/P8E80F9AEF21F6940 status=403 remote_addr=[::1] time_ms=27 duration=27.613311ms size=49 referer= handler=/api/datasources/uid/:uid
Already provided above
so as not to assume anything
did you restart grafana?
also what kind of install it is? dockerized or otherwise?
You’re right! :sweat_smile: It’s high chance I missed something(sssssss)
Oups forgot to mention I did it after any YAML update.
It is deployed on Kubernetes using Prometheus stack Helm chart: helm-charts/charts/kube-prometheus-stack at kube-prometheus-stack-52.1.0 · prometheus-community/helm-charts · GitHub
sorry meant to say how is grafana deployed
And that’s what I answered :smiley:
Update your datasources.yaml to include both deleteDatasources and the new datasource config with your desired uid:
apiVersion: 1
deleteDatasources:
- name: "Loki"
  orgId: 1
datasources:
- name: "Loki"
  uid: "loki"
  type: "loki"
  access: "proxy"
  1. Restart your Grafana instance (simple service restart)
  2. If using API to reload configs instead, ensure your service account has the specific provisioning:reload permission (being Admin isn’t enough)
Provisioned datasources can’t be deleted from UI or modified via API - they must be managed through the provisioning files.
It does the job to remove datasource.
However, when I removed deleteDatasources, it didn’t provision the datasource again…
Looked at logs I found several:
logger=context userId=0 orgId=0 uname= t=2025-04-14T11:00:44.639124887Z level=info msg= error="[identity.disabled] identity is disabled" remote_addr=[::1] traceID=
logger=context userId=0 orgId=0 uname= t=2025-04-14T11:00:44.639239648Z level=info msg="Request Completed" method=POST path=/api/admin/provisioning/dashboards/reload status=401 remote_addr=[::1] time_ms=20 duration=20.764481ms size=102 referer= handler=/api/admin/provisioning/dashboards/reload
It was before Grafana Pod was available, so not sure it is related…
Ok, I updated the config map and I get the same error log again… I’m using Helm chart, I will take a look if there’s a known issue…
Forgot to answer about this point. When I edit service account, I can’t set such permissions:
All things I can do:
  • Set a role: Viewer, Editor or Admin
  • Add permission:
    • I must select a kind: User or Team
    • Then select a user or a team
    • Select a permission: Edit or Admin
@thiagorodrigues
