13.2.0 (buildbb1a9a86), Cloud Advanced edition, in theproductionenvironment. -
Pull data from data souce -
Via Bigquery connector
What happened?
Any Boolean pulled will not have correct data, it takes the last boolean of any col and apply to all rows
It should read the actual data in my data source -
The code i run:
select true as `check`union all
select false
union all
select true
union all
select false
The data I get:
all false -
No error -
No
It looks like the native BOOL→dataframe conversion in the plugin isn’t copying each row’s value independently as every row ends up pointing at whatever the last row’s value was by the time the frame is built.
Panel 1 → native BOOL :
Query →
select true as `check` union all select false union all select true union all select false
All 4 rows returned false → matches the last value in the query, not the actual per row data.
Panel 2 → same values, cast to string (fixed):
Query →
select cast(true as string) as `check` union all select cast(false as string) union all select cast(true as string) union all select cast(false as string)
Result → correctly returned true, false, true, false.
Workaround is to cast any BOOLEAN column to STRING in your SQL instead of returning it natively. If you want it to display/filter as a boolean again, you can add a value mapping ("true" → true, "false" → false) via a field override on the panel.
Open this as a GitHub issue on the plugin repo if one doesn’t already exist →
Hi @fangdi just wanted to check if you got the solution . Happy to help further if you are facing any issues .
