I am working on windows 11.
Downloaded and ran the local Grafana 2 weeks ago and managed to login with ‘admin’ user and default ‘admin’ password.
I dont remember if I switched to another user, anyway, I can’t login with admin default credentials anymore.
trying to run the “grafana-cli --homepath “/usr/share/grafana” admin reset-admin-password blahblah” but I am getting:
Grafana-server Init Failed: Could not find config defaults, make sure homepath command line parameter is set or working directory is homepath
thanks @anon70503803
yes, I ran the command from the grafana cli directory.
but no, I am not sure that this is the correct homeopath. how can I know what it is?
Hi, I am also facing the same problem. I have tried by uncommenting the grafana.ini user and password params but it’s still the same. I tried grafana server restart as well. Please someone help me out here ?
