I am trying to login to the local server placed on my PC -
Since it is first time, I have just downloaded and installed it to day, then I am trying to use admin/admin. I am using port 4000. -
What happened?
It keeps telling me that it is wrong password or user name.
I expected to be logged in, and then asked if I want to change the password -
Nope -
Yes, from your webpage, but you are talking about port 3000 there, but i am only possible to open it on port 4000. It is also that port the customer.init file is setup to use.
