Can't define second datasource in dashboard
sorry for my poor english…
I’ve a weather dashborad based on an influx db.
Now I want to extend this with a 2. dashboard with air quality data (and playlist). This new data were written to another db in the same influx instance.
Because I want to reuse some auf the panels of 1. dashboard I’d cloned this one. But now I can’t define a new datasource based on the 2. database in influx (invalid url).
Maybe the datasources are specific for every dashboard? Can I delete the first defined datasource from 1. dashboard? Or is there an other way how to define the new data connection?
Many thanks Frank.
A single datasource in Grafana can be used by multiple dashboards. In a new dashboard, you can use panels with either the same datasource or different datasources.
If needed, you can also add a new datasource in Grafana settings and select it in your panels.
don’t know what I’ve doing false. But now I could define a new datasource at same influx instance.
So topic is solved. Thank you.
