Grafana 10.2
- What are you trying to achieve?
Installing grafana locally using github
What happened?
Shows error while running yarn and yarn build -
To make run yarn and next run make grafana command -
yes -
When we tried to set up a Grafana development environment in local and I tried to install yarn and yarn build. Then we faced this issue. I attached below the error message .
SyntaxError: missing ) after argument list
at wrapSafe (internal/modules/cjs/loader.js:979:16)
at Module._compile (internal/modules/cjs/loader.js:1027:27)
at Object.Module._extensions…js (internal/modules/cjs/loader.js:1092:10)
at Module.load (internal/modules/cjs/loader.js:928:32)
at Function.Module._load (internal/modules/cjs/loader.js:769:14)
at Function.executeUserEntryPoint as runMain
at internal/main/run_main_module.js:17:47
