What Grafana version and what operating system are you using? Grafana main version in GitHub
What are you trying to achieve? Run project locally for the first time
How are you trying to achieve it? Following the Developer Guide
What happened?
I’m just starting with Grafana from source. I cloned the GitHub repository following the steps in the developer guide, but when running yarn start, I get these messages, and the script fails. Are there any additional steps beyond those described in the guide that need to be followed?
What did you expect to happen? Success in all proccess
Package.json, I’m having problems with start script -
YN0002: │ @grafana-plugins/grafana-postgresql-datasource@workspace:public/app/plugins/datasource/grafana-postgresql-datasource doesn't provide react-dom (pdd2fa), requested by @grafana/plugin-ui and other dependencies.
➤ YN0002: │ @grafana-plugins/mssql@workspace:public/app/plugins/datasource/mssql doesn't provide react-dom (pfb198), requested by @grafana/plugin-ui and other dependencies.
➤ YN0002: │ @grafana-plugins/mysql@workspace:public/app/plugins/datasource/mysql doesn't provide react-dom (pab173), requested by @grafana/plugin-ui and other dependencies.
➤ YN0002: │ @grafana/eslint-plugin@workspace:packages/grafana-eslint-rules doesn't provide typescript (pd8d33), requested by @typescript-eslint/utils.
➤ YN0002: │ @grafana/flamegraph@workspace:packages/grafana-flamegraph doesn't provide react-dom (p0bf7f), requested by @testing-library/react and other dependencies.
➤ YN0002: │ @grafana/o11y-ds-frontend@workspace:packages/grafana-o11y-ds-frontend doesn't provide react-dom (p13635), requested by @grafana/plugin-ui and other dependencies.
➤ YN0002: │ @grafana/prometheus@workspace:packages/grafana-prometheus [655a6] doesn't provide @testing-library/dom (p9a3ab), requested by @testing-library/react and other dependencies.
➤ YN0002: │ @grafana/prometheus@workspace:packages/grafana-prometheus doesn't provide @testing-library/dom (pe123d), requested by @testing-library/react and other dependencies.
➤ YN0002: │ grafana@workspace:. doesn't provide jspdf (p91d71), requested by @siedlerchr/types-ol-ext.
- Did you follow any online instructions? If so, what is the URL? I checked on issues and community but I don’t find nothing more specific of my case
