v10.3.1 (00a22ff8b2), READ HAT -
visualize my data with time series -
by trying to use the visualization model -
What happened?
I get this message “Data is missing a number field” -
To see the trend line -
yes, it is a input.file telegraf configuration
[inputs.file]]
files = [“/output_sc_LTE.csv”]
data_format = “csv”
csv_header_row_count = 0
csv_column_names = [“SERVINGCELL”, “STATE”, “TECN”, “is_tdd”, “mcc”, “mnc”, “cellid”, “pcid”, “earfcn”, “freq_band_ind”, “ul_band width”, “dl_bandwidth”, “tac”, “rsrp”, “rsrq”, “rssi”, “cqi”, “tx_power”, “srxlev”]
csv_column_types = [“string”, “string”, “string”, “string”, “integer”, “integer”, “integer”, “integer”, “integer”, “integer”, “integer”, “integer”, “string”, “integer”, “integer”, “integer”, “integer”, “integer”, “integer”]
name_override = “ServingCellLTE”
csv_tag_columns = [“host”]
interval = “10m”
collection_offset = “6m”
No errors, just a message that says that the data is missing a number field. I do not know why since I have integers defined in each column. -
No
I would like to have a trend line for the RSSI value I collect with telegraf from a CSV file. The configuration is defined to have that column as integers but grafana is not detecting it. Can anyone help please?
