Cannot set host or job variables for new dashboard
    grafana-enterprise_10.3.3_amd64.deb
    at the top of the dashboard is “Host:” and “Job” - there is nothing in the fields.I am trying to change these to mymac:7100 and mymac_metrics as defined in the /etc/prometheus/prometheus.yml file, but I cannot set these fields.
These fields are set correctly for a bunch of other dashboards, but these where created with an earlier version of grafana.
I have tried editing the json of the dashboard, but it reverts removing my changes.
I have verified mymac:7100 and mymac_metrics are in the system by using the Explorer page.
I have also tried to set the “job” variable the same way it is set on an existing dashboard, in Settings → Variables → job ; I have copied the config exactly. At the bottom of the screen there is a “Preview of Values”, when I put an existing value into the regex box (safeserver_metrics) and click on “Run Query” the preview shows the value, however when i put mymac_metrics into the regex and click “Run Query” there is nothing.
It seems like something is missing when I added the mymac server metics, yet everything looks good, and the Explore tool shows data from the server.
There are no errors in journalctl log.
Can you just recreate these dashboards in your current Grafana version?
I have upgraded to the lastest 11.2.2 and narrowed down the issue – it seems like for querying grafana is “blind” to the new data series “job” that I added.
