Running grafana 11.5.1 of a rocky linux 9 server. Tested on firefox and edge browsers on windows.
I am having a overview dashboard with (among other things) status for a number of processes. After update from version 10.2 to 11.5, I am not able to resize the process panels any longer. Each panel is much higher than I want it:
I used to be able to drag the lower right corner of a panel to resize it, but that no longer works, when I touch that corner, I can click to change between name and value. I had to go into the dashboard json to edit the h: attribute of the panel. Is there somehow to adjust the size graphically?
