Tried for hours, file path is right everything is right, permissions right… just doesnt work.
Do you mean you are using the sqlite-datasource plugin or do you have problem with the Grafana database?
I’m using the Sqlite plug in. Some others mentioned issues with having it in the root or home directory which I double checked it isnt.
In that case, can you please provide the following:
- the location of your SQLite database
 - your Grafana setup (e.g. via Docker, direct on the PC, Cloud)
 - the exact error message you receive from Grafana
 - a terminal output of the permissions of the folder and all folders on the path up to the file as the Grafana user
