Grafana can't open sqlite datasource citing permissions but will work when db is opened in a separate command line session
    v9.4.3
    Be able to use sqlite3 database as datasource for dashboard
  1. Downloaded the sqlite plugin
  2. Defined the datasource
  3. Created the dashboard
  • What happened?
    When initially defining the datasource, I would get this error:
    error checking db: error checking for valid SQLite file: unable to open database file (14)
    However when i try to open the database in a command line session and until a run a command such as .tables
    Data source now shows as :
    Data source is working
    and the dashboard begins showing data.
    I expected that I don’t have to do any separate session to fire up the sqlite3 database and run a command for my Grafana dashboard to work
    I tried this grafana server configuration but to no avail:
    [Service]
    PrivateTmp=false
    ProtectHome=false
    for Grafana UI: see above
    for logs (just one of many similar logs):
    logger=plugin.frser-sqlite-datasource t=2024-02-19T16:46:20.274338561Z level=error msg=“Could not execute query” err=“unable to open database file (14)” query=“select upper(distinct(team)) from test_series where team like "XX%" or team like "XX%";\n\n”
    Recommended installation from:
    grafana-sqlite-datasource/docs/installation.md at main · fr-ser/grafana-sqlite-datasource · GitHub
welcome to forum @empunzalan
what operating system is this in?
what is the location of the sqlite file?
thanks for the welcome @yosiasz !
i’m running this on an ubuntu 18.04.4 LTS and the db file is in the defined grafana homedir /usr/share/grafana
sounds like grafana or the usr running grafana does not have permission to that folder?
the home directory for grafana:
drwxrwxr-t 6 grafana grafana 73728 Feb 19 16:11 /usr/share/grafana
the ownership is by a user named robot and has the following permissions:
-rwxrwxrwx 1 robot robot 29167616 Feb 19 15:28 test.db
these are the two users and their groups:
id robot
uid=1013(robot) gid=1001(robot) groups=1001(robot),115(grafana)
id grafana
uid=111(grafana) gid=115(grafana) groups=115(grafana),1001(robot)
notice that one is a member of the other user’s group.
as user grafana, i can open the db file owned by robot.
it seems that grafana has issues with data sources that are located in /usr/share. i’ve tried moving it to /var/lib and i don’t get any problems.
