Cannot access IPv6 datasource of Prometheus
    Grafana v10.3.1 (00a22ff8b2)
    I have a IPv6 based prometheus service behind nginx and I was trying to add it as datasource in grafana. Prometheus access URL: https:///prometheus/
    I have a grafana container v10.3.1 running and configure a yaml file to grafana’s /etc/grafana/provisioning/datasources/ as a datasource. My yaml file:
apiVersion: 1
deleteDatasources:
  - name: Prometheus
    orgId: 1
datasources:
  - name: PrometheusDataSource
    type: prometheus
    access: proxy
    orgId: 1
    url: https://[<IPv6 address>]/prometheus/
    isDefault: true
    jsonData:
      tlsSkipVerify: true
    editable: false
  • What happened?
    Data source added in grafana but cannot access. get error message:
"Post "https://[<IPv6 address>]/prometheus/api/v1/query": dial tcp [<IPv6 address>]:443: connect: cannot assign requested address - There was an error returned querying the Prometheus API."
    I can add above Prometheus as datasource in grafana and successful fetch data from it
    post in above questions
    Yes, post the error message in above questions.
    tried to google it but nothing useful found.
Does you container support IPv6?
