What Grafana version and what operating system are you using? Grafana cloud
Connect Local Prometheus Datasource to Grafana cloud. -
I have install Prometheus on a ec2 server with a node_exporter.
prometheus, version 3.1.0 (branch: HEAD, revision: 7086161a93b262aa0949dbf2aba15a5a7b13e0a3)
build user: root@74c225e2044f
build date: 20250102-13:52:43
go version: go1.23.4
platform: linux/amd64
tags: netgo,builtinassets,stringlabels
node_exporter, version 1.8.2 (branch: HEAD, revision: f1e0e8360aa60b6cb5e5cc1560bed348fc2c1895)
build user: root@03d440803209
build date: 20240714-11:53:45
go version: go1.22.5
tags: unknown
The Prometheus UI works and I have able to run querys.
I have a Grafana cloud account and I tried to add Prometheus Data sources,
Home > Connections > Data sources > prometheus
What happened?
There was an error returned querying the Prometheus API. -
success connections as I see when I run the same API in my browser:
{“status”:“success”,“data”:{“resultType”:“scalar”,“result”:[4,“2”]}} -
Get http://<DNS NAME>:9090/api/v1/query?query=1%2B1&time=4": dial tcp <MY IP>:9090: i/o timeout- There was an error returned querying the Prometheus API.
- Did you follow any online instructions? If so, what is the URL?
