I have no idea what’s wrong with my grafana but for some reason I just can’t access it on my browser. I had it running for a year but then all of a sudden it just stopped working. I have attached a screenshot of the systemctl status of grafana.
Hi @danielb,
Is grafana-server.service still running or did it crash after few seconds (check ps -ef | grep -i grafana or systemctl status grafana-server.servcie )? Are there any other logs in /var/log/grafana/grafana.log ? Can you check if SSL certificate from letsencrypt is still valid ?
I went into the logs and I found out that grafana didn’t have permissions to view the ssl certificates. So I just gave it permissions and it works now. Thanks for the help
Thanks,
Daniel
