Can we save a csv report to a location at periodic intervals
Hi All,
i am trying to find a possible way to save the csv report to a location at periodic intervals. i am using Grafana v9.3.6 (Open Source).
any possible way to achieve this.
you can but why would you use grafana for that?
what is your datasource?
Thanks for your reply ,
We have some dashboards in grafana which contains some reports that we need to save it as a csv in a location on periodic interval.
My datasource is vertica db
I have no experience with vertica db, but why you just don’t export data directly from datasource, without involvement of Grafana?
There are some examples in documentation:
Thanks again for sharing, my quesrion is mainly not related to exporting the data itself but its about scheduling that export and save it in a location instead of sending over the email :blush:
grafana does not provide such a feature.
