Is it possible to set Grafana to automatically export the data from a dashboard to a set location? (Apart from manually exporting the data one a week/month)
Thanks, Fergus
Thanks, Fergus
Welcome
One way to do it is create a cron jobthat uses grafana api.
But which dataare you talking about?
Can’t you just cron job the queries directly in you datasource ?
Hi @fergusthomson,
Welcome to the
community forum !!
I found this community post which has the exact same topic as yours and can find the solution/suggestions there.
Hope it helps.
