I have a visual and aggregate result showin in grafana.<<my_company>>.com. I can manually go to the menu click export and export the data to my local in format option I have. This works great. Is there a way I can script that in python that hit grafana server and get result what I need ? So that I can automate it.
Looking for info thanks in advance
Hello
and welcome to the forum, @sachinmans7
there are various tools like these for exporting dashboards, but not necessarily the data inside panels.
Question: Grafana is only a visualization layer. Can you not hit the DB directly? Or you are transforming the data inside Grafana?
You might need to write some sort of browser automation script?
I donโt there is an API endpoint that is the equivalent of the inspect โ data โ export workflow in the UI
