What happened?
Did you follow any online instructions? If so, what is the URL?[quote=“eglyn18, post:1, topic:40651, full:true”]
Hi
I have a question about the duplicate function of a panel:
I monitor 24 ports of a switch (with Polystat), so I have 48 query like this:
When I want to monitor another switch, I duplicate the panel. But I have to modify each query one by one to change the switch and the port (witch is reset when I change the switch)
Is there a way to make a script to change only the name of the switch for all queries ?
Thx in advance ![]()
[/quote]
Can we modify the query of a pannel which was build using library pannel without affecting the other pannel.
