Hai all,
I declared a custom value variable with the following values:
1 , 2 , 4 , 10, 50, 100
I want to give an alias or do masking for 100. can we change the value to “ALL”?
Could you please help me out?
Thanks & regards,
Bharath Kumar.
Hai all,
Thanks & regards,
Bharath Kumar.
it sounds like you want value mapping:
Or are you referring to alerts here? What grafana version?
Hello @anon70503803
No, I am not searching for value mapping. I am currently using grafana-8.3.
I declared a custom variable with custom values in comma-separated values as 1,2,5,10,20,50,100. Among those values, I want to mask the 100 as “ALL”.
Is it possible to do?
Thanks, @yosiasz. It’s working. Thanks for your support
All : < 100, 20% to 30% : <=30>=20,10% to 20% : <=20>=10,5% to 10% : <=10>=5 , Lt eq 5% : <=5
so similarly, I want to map a value to a key,
Ex :- NULL : (Here I don’t want to pass anything)
means I want to declare a null value to a key. will it be possible?
Could you please help me?
Thanks & regards,
Bharath Kumar.
If you dont to pass anything then its not a key value?
I want to pass null as a value. Will it be possible?
hello @yosiasz ,
how to use the escaped\ ,value in the above image?
can we use escape characters to pass a null value to a key?
