Can Promtail capture log as a block?
I have log data that looks like this:
1/1/2021 10:01:23 AM Memory
1/1/2021 10:01:23 AM 2300 Mb
1/1/2021 10:01:23 AM 23%
1/1/2021 10:01:13 AM Memory
1/1/2021 10:01:13 AM 2310 Mb
As you can see, the information I want to capture are in every 3 separate lines. Is it possible to get the 3 values as one “group” so I can display on Grafana?
Thank you!
As of Loki 2.0, i would suggest you check the multiline parsing stages.
Good Luck
Thanks @wlargou. I’ve already used it but it doesn’t seem to achieve the way I want so I was wondering if there is any alternative.
Thanks again.
hi @wlargou, I am wondering if you happen to know how to put label(s) (with the same timestamp) as legend on a dashboard? Data source is Loki or “Prometheus-Loki”.
Thanks in advance.
