Can not show label or custom template in alert
Hi!
I use Grafana 9’s alert,
I’m trying to set up an alert that finds relevant information about which instance is causing the alert. I add some items in the summery, but it still doesn’t show the value.
result:
I also used the template to solve the problem, but the problem still exists
Annotations:
  • summary = {{ template “mytemplate” . }}
What does your query and expressions look like?
