dp106
July 7, 2022, 1:52pm
1
Grafana Version 9.0.2
I am trying to “fool” the traces panel into displaying data from an MSSQL query. I thought this panel would be good for displaying a MSSQL sessions blocking tree if I can reformat the data into what the panel expects.
I’ve created a dummy table in my database with the following columns:
traceID
parentSpanID
startTime
operationName
logs
warnings
references
serviceName
duration
spanID
errorIconColor
serviceTags
stackTraces
tags
I got this list from here: TraceSpanRow
The logs and references columns seem to be my main issue at the moment. For example the logs column is a type of TraceLog . I’ve tried formatting is as follows:
"timestamp" : "15131543651",
"fields" : [
"key":"1",
"value":"2"
"key":"2",
"value":"22"
but get an error “n.map is not a function”.
Not sure if I’m close to cracking this or completely off the mark or its just impossible
could you please provide DDL and sample DML for this table?
ddl
create table traceLogs(
dml
insert into traceLogs
or maybe even a simple fake select statement with data
select 1 as traceID, 22 parentSpanID, 23232 startTime --etc
dp106
July 7, 2022, 8:25pm
3
This is the create table statement:
CREATE TABLE [dbo].[tracesTest](
[traceID] [varchar](20) NOT NULL,
[parentSpanID] [varchar](20) NULL,
[startTime] [datetime] NOT NULL,
[operationName] [varchar](20) NULL,
[logs] [varchar](max) NULL,
[warnings] [varchar](20) NULL,
[references] [varchar](20) NULL,
[serviceName] [varchar](20) NULL,
[duration] [numeric](18, 0) NULL,
[spanID] [varchar](20) NULL,
[errorIconColor] [varchar](20) NULL,
[serviceTags] [varchar](20) NULL,
[stackTraces] [varchar](20) NULL,
[tags] [varchar](20) NULL,
[combined] [varchar](max) NULL
I just have some dummy data in there at the moment while I try to get it to work:
traceID: 111
parentSpanID NULL
startTime 29/06/2022 12:59
operationName INSERT
logs [{ "timestamp" : "15131543651", "fields" : [{"key":"1","value":"2"},{"key":"2","value":"22"}] }]
warnings running
references SOS_SCHEDULER_YIELD
serviceName DRDBADW
duration 0
spanID 297
errorIconColor NULL
serviceTags NULL
stackTraces ["st_1","st_2"]
tags NULL
and which plugin are you using? Grafana Enterprise Traces?
dp106
July 8, 2022, 10:54am
5
The Traces panel that comes with v9…?
dp106
October 14, 2022, 6:06pm
7
Hey, no I’m afraid I did not
i keep getting this
maybe git pull the plugin, install and debug or build your own opentelemetry rest api to feed it?
