Can I trust the "X-Grafana-User" header value?
    Ubuntu 22, Grafana Version 9.5.3 (commit: 916d9793aa, branch: HEAD)
    Use the X-Grafana-User header sent in an API to filter results in that API. I wrote a Restful API accessed via JSON datasource (or Infinity) in Grafana. I plan to use this header value to limit returned results to a subset of all available results.
Specifically, I want to know if this header is:
  1. Set in the backend (i.e. by dataproxy) and hence, I think, can be trusted to reflect the actual Grafana authenticated user, OR
  2. Set in the front-end and so can be fudged by calling dataproxy directly with a false X-Grafana-User header
    I set the configuration as so
# In grafana-ini, I set:
[dataproxy]
send_user_header = true
… and then check to see if the header is set by the client or backend.
  • What happened?
    I saw the header as expected in the Restful API I called. I saw it:
print (request._request.headers['X-Grafana-User']) # "admin" or "user1", from Grafana
I looked in logs and the browser requests, and didn’t see X-Grafana-User. So I think it’s set in dataproxy and (therefore?) can be relied upon.
Note: This is not user authentication per-se, but related. I authenticate with the API via a seperate username/password, which is the same for all Grafana users. Many other questions relate to JSON/Auth but I think this is a unique, unanswered question.
Which api? Grafana’s or some other api?
Some other one, written by me.
It is not publicly accessible, but it takes something like https://api.com/foo/1 and returns { name: "foo", bars: 2 }. I can modify this api to read and use the header, if I can rely upon it. Authentication to the API is separate.
Looking at the source and searching for this header, I see it is set in ProxyUtil and middleware.
If my understanding is correct, the information flow goes:
Browser → make SQL → send to DataProxy (running on server) → middleware (header added) → my REST API (checks header) → JSON returned …
Since grafana-server adds the header, it can’t be injected from the browser, and can be relied on.
Can anyone confirm / deny?
It depends how paranoid you are and what kind of data you want to protect.
Attacker can use man in middle attack. You will say no problem: I will use HTTPS (TLS) communication.
Attacker then can use use attack on vulnerable TLS/cipher. You will say no problem: I will configure HTTPS properly.
Attacker then will be your secops guy and he will start TLS inspections. You will say: I gave up.
Cryptograhy is used usually in this case, e.g. JWT token, so server can verify received information, that it was not tampered during transit.
Not that paranoid! It’s not credit card numbers.
Putting aside the man-in-the-middle attack for a moment, can you comment specifically on the X-Grafana-User header?
ps. Thanks for the lead on JWT.
:person_shrugging: What is stopping the users to use the same authentication in the Postman, but sending different authorisation details (X-Grafana-User header)?
Did you think about attack outside of Grafana?
Authentication to the API is separate, meaning that the Grafana user has a seperate account on the API which is the only one that uses this header.
The original question hence could be clarified:
“Can I trust the X-Grafana-User as sent from Grafana”?
ps. Thanks for your time.
In the meantime, I’ve implemented a proof-of-concept, if you googled your way here!
I’m still interested to hear about the trust-worthiness of X-Grafana-User header and any experiences in using it (securely!?).
Feels like an anti pattern though very interesting
You are asking for security approval of your idea from random people on the internet. That indicates a security problem. Also you want to use feature, which IMHO was never intended to be used for proper authorisation.
IMHO:
  • yes, X-Grafana-User is trustworthy for POC/academic projects with unimportant data
  • no, X-Grafana-User is not trustworthy for serious (enterprise) use cases, because there is no way how value can be verified. I believe you also didn’t verified different attack vectors (just example to give you an ideas, not tested, e.g. what will happen if my username will be literally X-Grafana-User: admin and there is much more attacks: different encodings/injections which will change a meaning, …).
Thanks for your time and input. Lots to think about.
Hi yosaiz. I tend to agree! To consider further.
Can one use a sharp knife as a screw driver. Yes! Many of us have done it often
But one wrong slip and you can hurt yourself very seriously as it is not its intended use. Same analogy applies here.
