I deleted some panels from a dashboard. Later I made some modifications to other panels.
I would like to restore my deleted panels without losing my other modifications.
Can I restore a previous version of the dashboard as a new dashboard?
This is a bit tricky and you can’t do it directly but it is possible.
To make this clearer:
Thanks Daniel, actually I managed in a different way. First I duplicated the dashboard in its current incarnation, then I restored the previous version that I wanted. Then I deleted again the panels I didn’t want from the duplicate.
