Can I import Azure Cosmos db data into Grafana
Hi ,
I am trying to connect Azure Data explorer plugin data source in grafana but we don’t have cluster setup for my azure application and I can’t provide cluster url in that plugin. I tried simple JSON plugin but it requires a http url and our Azure portal url is https.
Do we have any alternatives plugins or any other way to access Azure cosmos db data into grafana?
Thanks for your help!
Regards,
Sreenivasa
Hi, did you figure it out? I have the same issue
Hello all! :wave: We recently released an Azure CosmosDB data source. Read more about it here
