Azure database as datasource
#1
Hi!
I’m having an azure sql database in a project I’m working on and is looking for a way to integrate my data with grafana, what is the easiest way? Is there any plugin that is fitting for this?
Thanks in advanced!
#2
No there is no plugin for Azure SQL server yet.
#3
Okay, that’s too bad.
I did however find the “grafana-simple-sql-datasource”-plugin, is that something that could be applicable?
#4
no, that will not work
