Can I color timecode values based on age?
    Grafana v10.1.5 (849c612fcb)
    Official Docker image
    In my Table Panel, I would like the Timestamp values for my datapoints to be colored based on their age relative to the current date. This could be represented by the raw timestamp values or using the data unit override for relative time e.g. 1 day old, 2 days old, etc.
    This is using the JSON API datasource.
    I am attempting to use Value Mappings, Thresholds, Data Types, and Color by Value overrides
  • What happened?
    I haven’t been able to achieve this functionality
    N/A
    N/A
    N/A
    N/A
In this table for example, the dates older than 3/14 might be colored orange and the ones older than 3/12 might be colored red.
Screenshot 2024-04-02 at 3.22.54 PM
welcome @scjoiner
Please a sample json data might be able to do it in jsonata
    "_id": "unique_id_string",
    "timestamp": "2024-04-02 19:48:47.077000",
    "key":"value"
A row in the table looks like this with other keys/values and I do Extract Fields (JSON) then I am trying to manipulate the timestamp value.
There’s not much more to the data than that - the JSON API query is simply $.result[*] and the returned rows populate a row in the table per list item. The row value is that string parsed to JSON via the Extract Fields transformation. Each of the key/value pairs in that extracted data becomes a table column including the Timestamp, maybe 10 columns in all. The other key/value pairs don’t matter for the purpose of this exercise - I just want to color the timestamp cell in each row based on its value relative to the current time/date.
The incoming timestamp is a string which until now I’ve displayed using a Cell Unit override with type “Datetime ISO” as shown in the first picture I uploaded.
This would be a typical JSON response from our API:
"result": [
	    "_id": "001",
	    "timestamp": "2024-05-07 01:01:33.077000",
	    "state":"active"
	    "_id": "002",
	    "timestamp": "2024-05-05 19:48:37.077000",
	    "state":"error"
	    "_id": "003",
	    "timestamp": "2024-04-29 20:04:45.077000",
	    "state":"complete"
This is the query field from Grafana:
These are the transformations I’m using - the first to extract the data into columns by key name and the rest are just filtering and renaming things to look pretty.
Let me know if I can provide anything further. Thanks!
Bumping due to age without fix
use the provided solution with jsonata.
Ok so the color field is working fine. How would I use that color value in the overrides for the timestamp table column only?
Thanks!
this way :point_up:
