What Grafana version and what operating system are you using? Grafana v10.2.2
What are you trying to achieve? I have a panel with ‘Bar Chart’ which is constructed from the result of a query that returns different fields and count. Each field and its count is represented in Bars. I need to set different colors for different bars. There are four transformations ‘Extract fields’ > ‘Filter by name’ > ‘Organize Fields’> ‘Reduce’. I need to apply ‘Add Field Override’ to a Field filtered by ‘Display Name’. This Field is to be from the Third Transformation. In this Transformation, I changed a Field named ‘launched’ to ‘App Launched’. When I try to ‘Add Field Override’ and look for the field, it returns the result of the last transformation (Reduce)’. Means, there is only one field available that is ‘Count’
How are you trying to achieve it? As explained above, there are four transformations ‘Extract fields’ > ‘Filter by name’ > ‘Organize Fields’> ‘Reduce’. I need to apply ‘Add Field Override’ to a Field filtered by ‘Display Name’. This Field is to be from the Third Transformation. In this Transformation, I changed a Field named ‘launched’ to ‘App Launched’. When I try to ‘Add Field Override’ and look for the field, it returns the result of the last transformation (Reduce)’. Means, there is only one field available that is ‘Count’
What happened? Since there is a transformation ‘Reduce’ after the ‘Organize fields’ transformation, the ‘Add Field Override’ for the Panel returns only one field that is ‘Count’ and so I am no table to set any override for a field that is result of an intermediate transformation.
What did you expect to happen? I need ‘Add Field Override’ to a field that is resulted from the third Transformation ‘Organize Fields’ . I need to color different bars with different colors
Can you copy/paste the configuration(s) that you are having problems with? - NA
Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were. - NA
Did you follow any online instructions? If so, what is the URL? - NA
A picture paints a thousand words so if you could post a snippet (even with dummy data) of what you’re trying to achieve.
But the the short answer should be yes - field overrides should technically still apply even for transformation generated column fields.
Also, any reason why you’re still using v10 if v12 is already out for a while? Who knows what bugs / glitches are in there.
