Can Grafana 9.5.14 Azure Monitor Plugin API URLs be Modified
  • Grafana 9.5.14 container running on RHEL8
  • Trying to connect the Azure Monitor plugin to our secret enclave within Azure.
  • I am using the Azure Monitor settings to set the client and tenant ID, and client secret.
  • The setup is unable to load the subscriptions. I tried adding the subscription manually, but get an error message showing the health check failure along with the URLs being used for the APIs. Those URLs are not the right ones we use for our Azure subscription.
  • Is there anyway to modify the URLs being used for the plugin? Or do you have another option for connecting to Azure Monitor/LogA?
