Grafana Cloud 8.1.2 -
I want to know if it is possible to update the credentials of an Azure Monitor datasource of my Grafana Cloud instance, meaning I want only to update the client secret, through a Grafana Cloud API. -
Through a Grafana Cloud API.
Thank you.
