Hello this might be a grafana beginner question but I am really stuck here.
I have this elastic index
"source_db_table1": {
"aliases": {
"fromkafka": {}
"mappings": {
"properties": {
"boolean_attr": {
"type": "boolean"
"date_attr": {
"type": "long"
"float_attr": {
"type": "float"
"id": {
"type": "long"
"int_attr": {
"type": "long"
"msgtime": {
"type": "long"
"str_attr": {
"type": "text",
"fields": {
"keyword": {
"type": "keyword",
"ignore_above": 256
"settings": {
"index": {
"creation_date": "1595292501292",
"number_of_shards": "1",
"number_of_replicas": "1",
"uuid": "O3reNKevS8OwfiwAPBgcpQ",
"version": {
"created": "7060199"
"provided_name": "source_db_table1"
and have a (secured) Elastic connection which tests fine. The time field is the date_attr field.
When I try to query that index, nothing comes out of it. Neither under the original name nor under the alias. But I am getting a weird QueryInsepctor output that seems to grow over time:
Object
request:Object
url:"api/datasources/proxy/1/_msearch?max_concurrent_shard_requests=5"
method:"POST"
data:"{"search_type":"query_then_fetch","ignore_unavailable":true,
"index":"fro017pmf17pm","fro018pmf18pm","fro019pmf19pm",
"fro020pmf20pm","fro021pmf21pm","fro022pmf22pm","fro023pmf23pm"]}
{"size":0,"query":{"bool":{"filter":[{"range":{"msgtime":
{"gte":1595440770687,"lte":1595462370688,"format":"epoch_millis"}}},
{"query_string":{"analyze_wildcard":true,"query":"*"}}]}},"aggs":{"2":{"date_histogram":
{"interval":"15s","field":"msgtime","min_doc_count":0,"extended_bounds":
{"min":1595440770687,"max":1595462370688},"format":"epoch_millis"},"aggs":{}}}} "
response:Object
took:1
responses:Array[1]
0:Object
Any ideas? What am I doing wrong?
