Elasticsearch-failed to parse search source. unknown search element [docvalue_fields]
Hi all,
Can anyone help me to resolve this error?
ERROR:failed to parse search source. unknown search element [docvalue_fields]
I am not able to display the JSON data into table,data is coming from the elasticsearch… it is displaying me the above error.
There is not enough information here to help you. What does the query look like? What does the raw query look like?
See this guide for examining the query:
Hi, I have the same problem.
I want to visualize my nginx logs in a table of grafana, thats logs are in my elasticsearch server and the datasource its ok, I can create line graphics with this datasource but when I try to create a table this error occurs
    "root_cause": [
            "type": "search_parse_exception",
            "reason": "failed to parse search source. unknown search element [docvalue_fields]",
            "line": 1,
            "col": 295
    "type": "search_phase_execution_exception",
    "reason": "all shards failed",
    "phase": "query",
    "grouped": true,
    "failed_shards": [
            "shard": 0,
            "index": "nginx-2018.01.22",
            "node": "YFkkW8JRSjqt9CyCJb_ajw",
            "reason": {
                "line": 1,
                "col": 295
That is my query inspector
“xhrStatus”: “complete”,
“request”: {
“method”: “POST”,
“url”: “api/datasources/proxy/2/_msearch”,
“data”: “{"search_type":"query_then_fetch","ignore_unavailable":true,"index":"nginx-"}\n{"size":500,"query":{"bool":{"filter":[{"range":{"@timestamp":{"gte":"1516429739561","lte":"1516531671023","format":"epoch_millis"}}},{"query_string":{"analyze_wildcard":true,"query":""}}]}},"sort":{"@timestamp":{"order":"desc","unmapped_type":"boolean"}},"script_fields":{},"docvalue_fields":["@timestamp"]}\n”
“response”: {
“responses”: [
“error”: {
“root_cause”: [
“type”: “search_parse_exception”,
“reason”: “failed to parse search source. unknown search element [docvalue_fields]”,
“line”: 1,
“col”: 295
“type”: “search_phase_execution_exception”,
“reason”: “all shards failed”,
“phase”: “query”,
“grouped”: true,
“failed_shards”: [
“shard”: 0,
“index”: “nginx-2018.01.22”,
“node”: “YFkkW8JRSjqt9CyCJb_ajw”,
“reason”: {
“line”: 1,
“col”: 295
What I doing wrong?
Sorry, I solved that doing update of my Elastic Search service.
