When i try to display some logs and its count from elastic search to grafana table some datas are missing,eg actual data :- “Reverse lookup error (bad ISP or attack)” but its displayed only reverse
Can you show your elasticsearch query and the table settings with screenshots.
Actual field was “Unknown problem somewhere in the system.” but its shows only “Unkown”
Note:- Its work properly on ELK with same grok
Elastic Search query :-
TAble query :-
What does your Options tab look like? Is it JSON Data?
My first thought is that this is something to do with your mapping. Is it analyzed or not analyzed? Do you have a signature.raw column that you can use instead?
See this for an explanation of analyzed/not analyzed:
http://thomasardal.com/terms-aggregations-on-analyzed-fields-in-elasticsearch/
hi,
Did you mean grafana option tab ?its not json data i am using both kibana and grafana,but this issue shows only in grafana .i am using same elastic search and logstash for both,if the problem was with my elastic search query its also make issue in kibana right ???
my logstash grok :-
filter {
grok {
match => ["message", "(?m)\*\* Alert %{DATA:timestamp_seconds}:%{SPACE}%{WORD}?%{SPACE}\- %{DATA:ossec_group}\n%{YEAR} %{SYSLOGTIMESTAMP:syslog_timestamp} \(%{DATA:reporting_host}\) %{IP:reporting_ip}\-\>%{DATA:reporting_source}\nRule: %{NONNEGINT:rule_number} \(level %{NONNEGINT:severity}\) \-\> '%{DATA:signature}'\n%{GREEDYDATA:remaining_message}"]
# Matches 2014 Mar 08 00:00:00 ossec-server01->/var/log/auth.log
match => ["message", "(?m)\*\* Alert %{DATA:timestamp_seconds}:%{SPACE}%{WORD}?%{SPACE}\- %{DATA:ossec_group}\n%{YEAR} %{SYSLOGTIMESTAMP:syslog_timestamp} %{DATA:reporting_host}\-\>%{DATA:reporting_source}\nRule: %{NONNEGINT:rule_number} \(level %{NONNEGINT:severity}\) \-\> '%{DATA:signature}'\n%{GREEDYDATA:remaining_message}"]
grok {
match => [“remaining_message”, “(?m)(Src IP: %{IP:src_ip}%{SPACE})?(Src Port: %{NONNEGINT:src_port}%{SPACE})?(Dst IP: %{IP:dst_ip}%{SPACE})?(Dst Port: %{NONNEGINT:dst_port}%{SPACE})?(User: %{USER:acct}%{SPACE})?%{GREEDYDATA:real_message}”]
geoip {
source => “src_ip”
Real log :-
** Alert 1513223582.153236: - syslog,errors,
2017 Dec 14 03:53:02 spoiler 10.20.4.145-[/spoiler]>/var/log/syslog
Rule: 1002 (level 2) -> 'Unknown problem somewhere in the system.'
Dec 13 22:53:01 micro-zoho CRON[1896]: (root) CMD (/bin/bash /root/scripts/check_error_pattern.sh)
I’m not sure how Kibana handles it - maybe it adds a multi-index for you? It is quite difficult to read the text you posted there - I am not sure what you are trying to show me.
- Can you show a screenshot of the options tab for your table panel in Grafana.
- Can you check the index of your signature column in Elasticsearch
Hi Danielle,
Sorry for the delay. actually i am new in grafana .I have not much
knowledge about how grafana fetch the index from elastic search.Please look
my elastic search index details its in json format and grafana table was
attached as file.
curl -XGET ‘http://privateip:9200/hide-*/_search?pretty’
"took" : 3,
"timed_out" : false,
"_shards" : {
"total" : 30,
"successful" : 30,
"failed" : 0
"hits" : {
"total" : 18402,
"max_score" : 1.0,
"hits" : [ {
"_index" : "ossec-2017.12.10",
"_type" : "ossec_filebeat",
"_id" : "AWBA1ddz5tockKIFV_LT",
"_score" : 1.0,
"_source" : {
"message" : "** Alert 1512910563.530938: - syslog,errors,\n2017 Dec
10 12:56:03 (e-agree_micro-zoho) 10.20.4.145->/var/log/syslog\nRule: 1002
(level 2) -> 'Unknown problem somewhere in the system.'\nDec 10 07:56:01
micro-zoho CRON[11412]: (root) CMD (/bin/bash
/root/scripts/check_error_pattern.sh)\n",
"@version" : "1",
"@timestamp" : "2017-12-10T14:30:31.546Z",
"input_type" : "log",
"source" : "/var/ossec/logs/alerts/alerts.log",
"beat" : {
"name" : "oss-01-prd-usw",
"hostname" : "oss-01-prd-usw",
"version" : "5.6.3"
"tags" : [ "ossec-server", "beats_input_codec_plain_applied" ],
"offset" : 531222,
"type" : "ossec_filebeat",
"host" : "oss-01-prd-usw",
"timestamp_seconds" : "1512910563.530938",
"ossec_group" : "syslog,errors,",
"syslog_timestamp" : "Dec 10 12:56:03",
"reporting_host" : "e-agree_micro-zoho",
"reporting_ip" : "10.20.4.145",
"reporting_source" : "/var/log/syslog",
"rule_number" : "1002",
"severity" : "2",
"**signature" : "Unknown problem somewhere in the system**.",
"remaining_message" : "Dec 10 07:56:01 micro-zoho CRON[11412]:
(root) CMD (/bin/bash /root/scripts/check_error_pattern.sh)\n",
"real_message" : "Dec 10 07:56:01 micro-zoho CRON[11412]: (root)
"_id" : "AWBA1ddz5tockKIFV_LX",
"_score" : 1.0,
"_source" : {
"message" : "** Alert 1512910683.532077: - syslog,errors,\n2017 Dec
10 12:58:03 (e-agree_micro-zoho) 10.20.4.145->/var/log/syslog\nRule: 1002
(level 2) -> 'Unknown problem somewhere in the system.'\nDec 10 07:58:01
micro-zoho CRON[11627]: (root) CMD (/bin/bash
/root/scripts/log_error_monitor.sh 2>&1)\n",
"@version" : "1",
"offset" : 532364,
"beat" : {
"version" : "5.6.3"
"timestamp_seconds" : "1512910683.532077",
"syslog_timestamp" : "Dec 10 12:58:03",
"severity" : "2",
"signature" : "Unknown problem somewhere in the system.",
"remaining_message" : "Dec 10 07:58:01 micro-zoho CRON[11627]:
(root) CMD (/bin/bash /root/scripts/log_error_monitor.sh 2>&1)\n",
"real_message" : "Dec 10 07:58:01 micro-zoho CRON[11627]: (root)
"_id" : "AWBA1ddz5tockKIFV_LY",
"_score" : 1.0,
"_source" : {
"message" : "** Alert 1512910741.532364: - syslog,errors,\n2017 Dec
10 12:59:01 (e-agree_micro-zoho) 10.20.4.145->/var/log/syslog\nRule: 1002
(level 2) -> 'Unknown problem somewhere in the system.'\nDec 10 07:59:01
micro-zoho CRON[11739]: (root) CMD (/bin/bash
"@version" : "1",
"offset" : 532648,
"beat" : {
"version" : "5.6.3",
"timestamp_seconds" : "1512910741.532364",
"syslog_timestamp" : "Dec 10 12:59:01",
"severity" : "2",
"remaining_message" : "Dec 10 07:59:01 micro-zoho CRON[11739]:
"real_message" : "Dec 10 07:59:01 micro-zoho CRON[11739]: (root)
"_id" : "AWBA1ddz5tockKIFV_La",
"_score" : 1.0,
"_source" : {
"message" : "** Alert 1512910801.532935: - syslog,errors,\n2017 Dec
10 13:00:01 (e-agree_micro-zoho) 10.20.4.145->/var/log/syslog\nRule: 1002
(level 2) -> 'Unknown problem somewhere in the system.'\nDec 10 08:00:01
micro-zoho CRON[11845]: (root) CMD (/bin/bash
"@version" : "1",
"beat" : {
"version" : "5.6.3"
"offset" : 533219,
"timestamp_seconds" : "1512910801.532935",
"syslog_timestamp" : "Dec 10 13:00:01",
"severity" : "2",
"remaining_message" : "Dec 10 08:00:01 micro-zoho CRON[11845]:
"real_message" : "Dec 10 08:00:01 micro-zoho CRON[11845]: (root)
"_id" : "AWBA1ddz5tockKIFV_Le",
"_score" : 1.0,
"_source" : {
"message" : "** Alert 1512910861.534129: - syslog,errors,\n2017 Dec
10 13:01:01 (e-agree_micro-zoho) 10.20.4.145->/var/log/syslog\nRule: 1002
(level 2) -> 'Unknown problem somewhere in the system.'\nDec 10 08:01:01
micro-zoho CRON[11956]: (root) CMD (/bin/bash
"@version" : "1",
"beat" : {
"offset" : 534416,
"timestamp_seconds" : "1512910861.534129",
"syslog_timestamp" : "Dec 10 13:01:01",
"reporting_ip" : "hide",
"severity" : "2",
"remaining_message" : "Dec 10 08:01:01 micro-zoho CRON[11956]:
"real_message" : "Dec 10 08:01:01 micro-zoho CRON[11956]: (root)
"_id" : "AWBA1ddz5tockKIFV_Lf",
"_score" : 1.0,
"_source" : {
"message" : "** Alert 1512910921.534416: - syslog,errors,\n2017 Dec
10 13:02:01 (e-agree_micro-zoho) 10.20.4.145->/var/log/syslog\nRule: 1002
(level 2) -> 'Unknown problem somewhere in the system.'\nDec 10 08:02:01
micro-zoho CRON[12060]: (root) CMD (/bin/bash
"@version" : "1",
"beat" : {
"version" : "5.6.3"
"offset" : 534703,
"timestamp_seconds" : "1512910921.534416",
"syslog_timestamp" : "Dec 10 13:02:01",
"severity" : "2",
"remaining_message" : "Dec 10 08:02:01 micro-zoho CRON[12060]:
"real_message" : "Dec 10 08:02:01 micro-zoho CRON[12060]: (root)
"_id" : "AWBA1ddz5tockKIFV_Lh",
"_score" : 1.0,
"_source" : {
"message" : "** Alert 1512910983.534987: - syslog,errors,\n2017 Dec
10 13:03:03 (e-agree_micro-zoho) 10.20.4.145->/var/log/syslog\nRule: 1002
(level 2) -> 'Unknown problem somewhere in the system.'\nDec 10 08:03:01
micro-zoho CRON[12163]: (root) CMD (/bin/bash
"@version" : "1",
"offset" : 535274,
"beat" : {
"version" : "5.6.3"
"timestamp_seconds" : "1512910983.534987",
"syslog_timestamp" : "Dec 10 13:03:03",
"severity" : "2",
"remaining_message" : "Dec 10 08:03:01 micro-zoho CRON[12163]:
"real_message" : "Dec 10 08:03:01 micro-zoho CRON[12163]: (root)
"_id" : "AWBA1ddz5tockKIFV_Li",
"_score" : 1.0,
"_source" : {
"message" : "** Alert 1512910983.535274: - syslog,errors,\n2017 Dec
micro-zoho CRON[12167]: (root) CMD (/bin/bash
"@version" : "1",
"beat" : {
"version" : "5.6.3"
"offset" : 535558,
"timestamp_seconds" : "1512910983.535274",
"severity" : "2",
"remaining_message" : "Dec 10 08:03:01 micro-zoho CRON[12167]:
"real_message" : "Dec 10 08:03:01 micro-zoho CRON[12167]: (root)
"_id" : "AWBA1ddz5tockKIFV_Lo",
"_score" : 1.0,
"_source" : {
"message" : "** Alert 1512911161.537039: - syslog,errors,\n2017 Dec
10 13:06:01 (e-agree_micro-zoho) 10.20.4.145->/var/log/syslog\nRule: 1002
(level 2) -> 'Unknown problem somewhere in the system.'\nDec 10 08:06:01
micro-zoho CRON[12500]: (root) CMD (/bin/bash
"@version" : "1",
"beat" : {
"version" : "5.6.3"
"offset" : 537323,
"timestamp_seconds" : "1512911161.537039",
"syslog_timestamp" : "Dec 10 13:06:01",
"severity" : "2",
"remaining_message" : "Dec 10 08:06:01 micro-zoho CRON[12500]:
"real_message" : "Dec 10 08:06:01 micro-zoho CRON[12500]: (root)
"_id" : "AWBA1ddz5tockKIFV_Lp",
"_score" : 1.0,
"_source" : {
"message" : "** Alert 1512911161.537323: - syslog,errors,\n2017 Dec
micro-zoho CRON[12501]: (root) CMD (/bin/bash
"@version" : "1",
"beat" : {
"version" : "5.6.3"
"offset" : 537610,
"timestamp_seconds" : "1512911161.537323",
"severity" : "2",
"remaining_message" : "Dec 10 08:06:01 micro-zoho CRON[12501]:
"real_message" : "Dec 10 08:06:01 micro-zoho CRON[12501]: (root)
You can look at the mapping like this:
curl http://privateip:9200/hide-*/_mapping
Here is an snippet from a mapping response with an example of a field that has is not_analyzed:
"@metric": {
"type": "string",
"index": "not_analyzed"
The above example is from an old version of Elasticsearch. Hopefully you are using ES 5.0 and have the text and keyword defaults instead of string:
Hi daniellee,
Issue resolved. actually i am used old version of ES(v2) and now i am
change it to ES(v5) and mapped index as keyword field .its working properly.
Thank you for your support.
