Can a playlist pass template variables to a dashboard?
I would like to create a playlist that includes the same dashboard multiple times, but would like to select a non-default template variable value each time. I don’t see a way to do this, is it possible?
I thought perhaps if I could submit the JSON for the playlist I could set it directly in the URL used, but then I realised there doesn’t appear to be any import/export options either.
Any ideas? Creating static versions of the dashboards with the template variable combinations I want would be very much less than ideal.
Sorry no. There is a feature request open for it: https://github.com/grafana/grafana/issues/773
