I am creating a dashboard on Grafana Cloud. The data, which has to be interpreted, updates at 8 AM daily and is stored on AWS Redshift DW.
For Grafana Dashboard, Redshift has to be on all the time, which turns out to be expensive.
Is there a way the dashboard automatically updates at a particular time? Then, this data is shown till the next day the information is updated, instead of querying every time?
I don’t believe you can specify an absolute refresh time - you can only
specify a refresh interval, but the times of the refreshes will then depend on
when the dashboard was loaded into any given browser.
For a situation like this I would pull the data from AWS into a local data
store at 08:00 each day, and then tell Grafana to consult the local data store
whenever it needs to.
