Calendar Plugin | set colour for events
I have been trying to use community calendar plugin for one of my dashboard, and wanted to know if there is any option to control the colour of events displayed on the calendar. By default it creates an entry with Green colour for multiple date event.
Thanks in advance.
Yusuf M
you should probably link to the plugin you are using so others know :slight_smile:
My bad, I was referring to this plugin Calendar plugin for Grafana | Grafana Labs
@marcusolsson might have some insight on this.
you might also want to file a feature request / issue about that in the plugin’s repo:
