Hi everyone, I am looking for a way to get google calendar events displayed in a panel on my dashboard. I saw the plugin for annotations, but I’d like to actually display people’s schedules in its own panel. Has anyone found a way to do this? Thanks!
The Text panel allows for HTML, which should let you embed the Google calendar (depending what your calendar security settings are), but you need to change a default setting to allow the embed code to work depending what version of Grafana you have. If you are a server admin for an instance running Grafana 6.0 or later you need to change the configuration file to set Disable Sanitize html - as noted on the docs, this can be a bit of a security risk: https://grafana.com/docs/grafana/latest/administration/configuration/#disable_sanitize_html
