Calculation in Tables
Hi all,
In single stat panel I can choose the option “range” to calculate the diffrence between min and max, this would be very helpful in Tables, however I do not see any option there? Is that possible in Tables at all?
Hope someone can tell me some tricks :slightly_smiling_face:
-Siggi
That’s not possible in the table panel but you might be able to do it in the data source query depending on what data source your using.
Hi Bergquist,
Thank you for the answer! I am using zabbix as datasource, however I am that new to grafana I do not understand all the options in the DS, hope this is possible with zabbix it would be awesome.
-Siggi
You can do it by adding a new field from calculation and then selecting range as your option. I would have to see the table to help more.
Use the grafana transformation
add field from calculatoin
reduce
it will help to fulfill your requirement.
