Business Forms : Update Request Payload
Hello to the ones who will read this !
I’m facing an issue (again haha) with the business Forms plugin that might be because of Grafana or my error.
This is the “Update Request” :
And this is the “Update Request Payload” :
The goal is to combine both the insert statements to be able to add values to both the tables.
Each insert statement works well separately, the issue is when I use them both at once.
I could create another visualization for the second table, I’m still curious about why this first option doesn’t work.
Thanks in advance !
Leane
@LeaneM I don’t believe that transactions or multiple statements are supported in the data source.
I would recommend to use function/procedures to implement multiple statements and transactions.
@mikhailvolkov Got it thank you !
So where should I write this procedure/function exactly ? (in the Business Forms, as a query, …)
https://dev.mysql.com/doc/refman/8.4/en/create-procedure.html
Thank you there, will read it.
Appreciating your help !
