Volkovlabs Data manipulation, insert/update more than 1 table
I use Data manipulation from Volkovlabs and now i want to update 2 tables in my mysql-database.
This is what i have tried
const payload = {};
elements.forEach((element) => {
  if (!element.value) {
    return;
  payload[element.id] = element.value;
// Create a object for each SQL-question
const queryInsert = {
  rawSql: `INSERT INTO anc_test_result (fid, result, comment, user) VALUES ('${payload.fid}', '${payload.result}', '${payload.comment}', '${__user.id}')`,
  format: 'table',
const queryUpdate = {
  rawSql: `INSERT INTO anc_test_status (fid, status) VALUES ('${payload.fid}', 'Test incomming') ON DUPLICATE KEY UPDATE status = VALUES(status)`,
  format: 'table',
// Return a list with the separate SQL-question.
return [queryInsert, queryUpdate];
and when i run each of them separately they work.
Is this even possible to do?
The problem is that the value for status is a static text and could be different for different sql-querys
Thanks! I had not work with stored procedures before, but when i read about and test it, it work at first try. Thanks!
