Bug inside of ingress helm installation of loki?
    Newest helm chart of loki installation on kubernetes 1.26.10
    Installing loki on kubernetes through helm, adding an service and ingress to the deployment
    Using helm and applying a custom values.yaml
  • What happened?
    We have a standard config for adding ingress to a helm values installation:
ingress:
  enabled: true
  className: "nginx"
  pathtype: ImplementationSpecific
  annotations: {}
  kubernetes.io/ingress.class: nginx
  hosts:
    - host: loki.example.com
      secretName: ingress-tls
      paths:
        - path: /
          pathType: Prefix
          backend:
            service:
              port:
But for some reason, helm installation of loki is not accepting these values and will throw this error:
install.go:251: [debug] WARNING: This chart or one of its subcharts contains CRDs. Rendering may fail or contain inaccuracies.
Error: INSTALLATION FAILED: template: loki/templates/ingress.yaml:35:19: executing "loki/templates/ingress.yaml" at <.>: wrong type for value; expected string; got map[string]interface {}
helm.go:84: [debug] templ
    The standard ingress config to be working.
Show that loki/templates/ingress.yaml:35:19, your values and rendered templates, pls.
